Els27 - это адаптер
Для диагностики форскан
- Полное имя: Lukasz
Re: Бортовой компьютер (Программа ELM-FFN)
Casper, hello again!
Thank you for translating the settings. You've been very helpful.
Could you please translate a few more settings? I cannot understand them.
IPC -> Компоненты
Доп. информационный дисплейный модуль - what kind of additinoal module is it?
IPC -> Опции
Мгновенный расход - I understand that this setting is for enabling instantaneous (current) fuel consumption. Can I use this option if I have Ford Fusion without on-board computer (БК) - my front display only shows distance letf (km), trip distance and total distance.
Индикация ремней без звука and Индикация ремней со звуком - can I use this options without having БК on my car? When I check any of those settings and then I start driving, I don't see or hear any alert if my seat-belt is not fastened.
Настройка через БК (запрет шаманства) - what does it do?
GEM -> центральный замок
Простые замки (отмена Дв. Зап.) - is this a special kind of "soft" door locking? What is the difference between checked and not checked? Why it says that accumulator needs to be disconnected after change?
Again, thanks a lot for help!
Regards,
Luke
IPC -> Компоненты
IPC -> Опции
Regards,
Luke
ceiling player, only PLUS versionluke писал(а):what kind of additinoal module is it?
Need high series may be. I don't know is work on middle series.luke писал(а): I understand that this setting is for enabling instantaneous (current) fuel consumption. Can I use this option if I have Ford Fusion without on-board computer (БК) - my front display only shows distance letf (km), trip distance and total distance.
You must install the seat belt with sensor beltluke писал(а):can I use this options without having БК on my car? When I check any of those settings and then I start driving, I don't see or hear any alert if my seat-belt is not fastened.
http://www.fusionguru.ru/articles/tunin ... _remna.htm
Switch on board computer and allows him to control other blocksluke писал(а):what does it do?
Yes. Special kind.luke писал(а):is this a special kind of "soft" door locking?
The set of parameters depends on the configuration and may not work in some versions. Checked - which means you can use, not tested - so I do not know their action. Need Check - means it is necessary to check on the other trim levels, but this was not possible.luke писал(а):What is the difference between checked and not checked?
To correct work.luke писал(а):Why it says that accumulator needs to be disconnected after change?
Сегодня в программе посмотрел в раздел «одометр / корректировка»: в верхней строке были цифры пробега – 96280, а в нижней строке – 96296. Скажите это нормально или кто-то вмешивался в мозги машины.
Нормально.
Re: Re:
Адаптер - http://ffclub.ru/topic/311647/romca85 писал(а):Где его можно приобрести?*Casper* писал(а):Els27 - это адаптер
Приобретение _ http://ffclub.ru/topic/344211
- Полное имя: Роман Зайцев
Re: Re:
Я не состою в этом клубе.SAnat писал(а):Адаптер - http://ffclub.ru/topic/311647/romca85 писал(а):Где его можно приобрести?*Casper* писал(а):Els27 - это адаптер
У меня есть, эта прибамбасина, но если честно я её как получил так и не испытал, и супруга убрала так что сама не помнит куда...romca85 писал(а):Я не состою в этом клубе.
- Полное имя: Deniss
Я тоже, но заказал!romca85 писал(а):Я не состою в этом клубе.
Вот тема об этом адаптере на нашем форуме - ССЫЛКА! Напиши ему в личку или на e-mail и он тебе ответит!
romca85,
Местный парень, ему незачем заказывать может просто приехать ко мне и взять на время!
Но сначала его найти у меня в доме...
Тут то и дело - Найти!maxs-vd писал(а):Но сначала его найти у меня в доме..
Форскан нюхает, а ELM-FFN -не мышит, требует ELM.
serezhiki, ну уж не знаю. ЕЛС отвечает как и эльм по сути. Лог есть? Что именно говорить эльм-ффн?
serezhiki писал(а):протокол не закачал в комп!
О, привет Макс! Если найдёшь маякни пожалуйста!maxs-vd писал(а):У меня есть, эта прибамбасина, но если честно я её как получил так и не испытал, и супруга убрала так что сама не помнит куда...romca85 писал(а):Я не состою в этом клубе.
Запустился, жить мне не давала несовместимость с Win 7... При запуске в режиме совместимости с ХР - ожило.*Casper* писал(а):serezhiki писал(а):протокол не закачал в комп!чиво?
Что до протокола, дык при колдунстве дома видимо случайно зашел в режиме совместимости и нетбук нашел адаптер (я же это связал с тыканьем кнопки в менюшке), а в гараже весь мозг вынесло, пока догадался. Аж порты переименовывал...
протестил несколько программ, все цепляются
Ошибки ГЕМа есть, с лампочками связано, тьфу на них!!!
Странно, у меня и на 8 идет безо всяких совметсимостей
Да, не понял, отсутствует отклик программы по М-шине... по Н-шине есть. Так должно быть? Или опять мои лыжи не едут?
